Part number 'A' ??? WT...
@wholesalehyundaiparts
what does the part number designation 'encircled capital-A' mean ? On my microfiche the brake line from Hecu to rear right wheel has the P/N 58735-39401. Whatever Online catalog I ask, I get 'not found' for this number. On your diagram the number is replaced by that 'A'. http://www.wholesalehyundaiparts.com...9958-58701.jpg What's the exact meaning of this 'A' ??? THX for any enlightenment on this ... |
The A with the circle around it is just the brake lines and where the upper and lower diagrams connect.
Ok, but what about the P/N for these pieces of brake line ?
(Post 51344)
Originally Posted by e3tom
(Post 51347)
It looks like 58712/58713/58715A/58718E/58722D are the callout numbers for the lines themselves. If you want to get these I would suggest buying locally because shipping these things is a nightmare. If you would like me to give you the full part numbers I would be happy to, I just need your VIN. |
Originally Posted by WholesaleHyundaiParts
(Post 51366)
I have no VIN since this is about a purchase candidate car I visited. It failed inspection due to (among a row of other things like defeated airbag light ...) excessive rust on this line in the section where it runs parallel to the rear subframe. I'd probably buy some line piece locally as you suggested (if I buy the car). Was just curious what the A means (since it's not present on the fiche pictures, there it has part numbers). Thx again. |
Good luck with you car shopping! :)
