Problems solving trouble codes.
Old Nov 25, 2008 | 10:23 AM
zhudlin's Avatar
Default Problems solving trouble codes.
I used a code reader and it said that the crankshaft position sensor had a circuit problem. I finally got the part in but now I have to take off the crankshaft pulley (harmonic balancer) but there are no threads on the balancer so I can use a pulley puller. I need help.
Zach
Old Dec 31, 2008 | 04:12 PM
Skrag55's Avatar
Default RE: Problems solving trouble codes.
To replace the crankshaft position sensor you need to get down to your timing belt. Which involves taking off the timing belt covers, removing a motor mount, and getting the alternator out of the way. It's quite the lengthy process to replace it. I would recommend taking it to a dealership or getting a manual on the vehicle.
Old Dec 31, 2008 | 11:21 PM
jsinton's Avatar
Banned
If you're just worried about getting the crank pulley off, it's not such a big deal. Usually they just slide off once you get the crank bolt off. Normally people complain about not being able to crank pulley bolt off, not the pulley itself.
kibut
Feb 12, 2008 03:29 PM
cts2001
Aug 29, 2007 04:57 PM
jnord
Jan 26, 2006 04:49 PM
jnord
Jan 18, 2006 03:11 PM
fost9508
Jun 24, 2005 03:27 PM
