Rough Idle and stall on cold start
  #11
Old 10-20-2017, 09:41 AM
brucelee's Avatar
Originally Posted by JockeHyundai
Crank shaft position sensor?
I dont expect that to be the issue. If that was the problem I would expect a code relating to it.
  #12
Old 10-20-2017, 09:44 AM
brucelee's Avatar
Default Update
I noticed a pattern. It starts perfectly fine on cold mornings. The fuel trims are way negative, indicating a rich condition which the computer is compensating for. -15% and -19% on each bank.
Will be changing fuel pressure regulator this weekend.
  #13
Old 11-01-2017, 02:37 PM
brucelee's Avatar
Thumbs up Solved!!!!
Fuel pressure regulator was the problem. Starts smooth and idles fine now.
Better fuel economy and smoother engine.
  #14
Old 08-10-2018, 11:34 AM
JimC's Avatar
Default Was trouble repaired?
I have the same trouble with my 2004 XG350....65k miles.....any luck with your troubles yet?
  #15
Old 08-10-2018, 11:36 AM
JimC's Avatar
Ooops, sorry, missed your final threads....cool will try the fuel regulator. Thanks !
  #16
Old 08-11-2018, 07:00 AM
If the fuel press regulator doesn't correct the problem, consider the crank sensor.
Here is why;
A malfunctioning crank sensor "Does not throw a code" !
If everything else checks out , smart move to change it.
  #17
Old 03-07-2021, 05:55 AM
Manic Mechanic's Avatar
[QUOTE=brucelee;53407]Hello,
I have an XG350 2004 with 60k miles on it. The first start of the day is rough. The car idles very very rough and and sometimes stalls. The engine will sometimes rev up by its self just before stall.
Im in the process of changing all plugs and EGR valve. Any one else had this or can point me in the right direction? Once its warm it idles well.
As an ASE Certified Master Automotive Technician, I honestly try to advise everyone to not waste their time and money replacing plugs, primary/secondary ignition etc until the actual problem has been properly diagnosed. I honestly wish I could start charging my customers extra money if they worked on the vehicle first. 99 times out of 100 they end up ruining a cylinder head from improper plug installment or they don’t know that a plug is supposed to be torqued to the proper specs. Years ago I also had problems with people not knowing that a plug needs to be gapped or what that even meant LOL Even though these days most plugs are pre-gapped, most people end up causing more problems on top of what was wrong already and I’m forced to fix whatever it is that they did wrong before I’m able to begin making a diagnosis on the original problem. So under most circumstances I advise people to leave the vehicle problems to a good, trustworthy technician (avoid chains and franchises at all costs!!!!!). Unless you have some form of automotive repair training and own a professional set of tools, I really can’t stress enough how important it is to give the car to a service professional as is! Not only will it save them a headache, but it will save you time and money 💰💰💰 Hope this helps!
mweide27
10-02-2017 09:49 PM
gosswiller
07-11-2015 12:04 PM
mahinakane
04-15-2012 09:46 PM
HangingAround
09-10-2009 02:47 PM
ChrisV
01-29-2009 02:08 PM
Quick Reply: Rough Idle and stall on cold start
