Serpentine Belt
Has anyone removed and replace the forward serpentine belt on a 2002 XG350. I am having trouble figuring how to relieve the tension on the belt. I found the tensioner pulley but cannot find anyway to relieve the tension. Thanks.
RE: Serpentine Belt
forward meaning the a/c compressor belt? if so remove the left front wheel, ten bolts holding plastic cover, loosen 14mm bolt on adjuster pulley then loosen 14mm under the bracket for the pulley.
