Throttle peddel position sensor - I think
My 05 XG 350 has an intermittent problemwith the throttle. It has thrown the check engine light a few times and I wasable to reset it. I was in a hurry so I didn't take time to write the code downbut remembered that it said something about the throttle position sensor. Ichecked on-line and found that my Hyundai has two - one the TPS on the throttlebody and the other attached to the peddle, so I decided to wait until I couldget the code and hopefully figure out which one to replace.
The other day it happens and this time the car went into limp mode (thethrottle would not work) so I checked the code before resetting. The code wasP0224 Throttle/pedal sensor switch B intermittent so I am guessing that it isnot the one on the throttle body. :confused: I think part # 35357-3B011 is for code P0224 but am not sure. :confused: I don’t want to spend $120 –$140 and getthe wrong one if I can get by with part #502-0011 for under $90 Can someone guide me to the right part number and/or a linkto the right one?:rolleyes: |
What's wrong with THIS?
I have been trying to get assistance with an APS problem for over a month and have no replies on three different Hyundai forums. http://www.hyundaiperformance.com/fo...ace_crying.png
This is significantly different from what happens on the Audi forums (my former vehicle) where I got loads of help, suggestions and even ways to save money on repairs. http://www.hyundaiperformance.com/fo...e_surprise.png Hate to say it but it seems that Hyundai drivers are just stick, twist, select, and push people. http://www.hyundaiperformance.com/fo...face_devil.png Stick the key in, twist the key, select drive and push the peddle without having any clue as to what is happening! http://www.hyundaiperformance.com/fo...ies/tongue.gif It's sad because the Hyundai deserves more! http://www.hyundaiperformance.com/fo...ilies/cool.gif |
The pedal sensor is a common problem with XG's. I can't guarantee that's the issue without testing the one in your car now but it's usually that one.
Thanks, My scanner comes up with P0224 and says intermittent APS signal.
I do a reset and everything is Ok for a few days. I finally decided to get the APS thru EBay from a Hyundai dealer in the state of Washington for $117 plus about $12 shipping... Far less than I could get it anywhere else. Now all I need is a few days of above zero weather and some time to see if it works. If it doesn't I'll just continue to use the old reliable 2006 Dodge Grand Caravan with 240,000 miles that has never had the spark plugs or wires replaced. Ya I know not a wise move with the Dodge but it still starts easily and gets good mileage. |
