Top Engine Cover Bolts
Does anyone know what size the bolts are that hold the top plastic engine cover to the engine on a 2002 XG350L? I purchased the vehicle about a month ago and the engine cover was missing. I purchased an engine cover, but do not have the bolts. Any help would be appreciated.
most likely they are 6 mm or so.... most hardware stores do carry metric stuff in stock....
Thanks for your help. You were correct about the 6mm bolt.
Items/Tools Required:
Phillips screwdriver or flathead screwdriver for trimming swap out the dashboard dome Cut the Battery Off Take off the dashboard trim. Find the screws and remove them. Take off the dashboard dome. Cut the wiring, if necessary. Put the New Dashboard Dome in Place Reattach the wiring, if necessary. Fasten using screws Reattach the dashboard trim. Link the Battery Test back in. |
