Water pump won't clear
Old 05-16-2017, 08:18 PM
Robs Page's Avatar
Default Water pump won't clear
I'm in the process of removing my water pump but can't get it to clear the engine mount studs The pulley seems to be hitting It and won't let the pump slide out. I double checked to make sure all the bolts were loose. The pump is loose and moves but I can't get it out far enough to remove. Anything else I should do to give me more room???? Thanks.
Old 05-17-2017, 07:31 AM
avisitor's Avatar
Most cars require putting a big piece of wood under the oil pan and jacking the engine a little while taking out the motor mount.
After that, the engine can be lifted slightly to aid in taking the water pump out.
Good luck with that
fudgiewhale
02-17-2011 10:39 AM
Vanga
08-30-2010 07:36 PM
D16z6
09-12-2007 11:39 PM
ArtZPACarGal711
08-19-2007 04:28 PM
sonya36dd
02-07-2007 06:43 PM
Quick Reply: Water pump won't clear
