Loose Rearview Mirror
Old 04-16-2009, 07:25 PM
Joe Mc's Avatar
Default Loose Rearview Mirror
2005 - How do you get to the fastener that holds the rearview mirror to the mount on the windshield? I'm assuming the plastic cover needs to come off, but how is the cover removed?
Old 05-03-2009, 10:12 AM
Joe Mc's Avatar
Anyone ! ! !
Old 05-03-2009, 01:36 PM
ken99's Avatar
I haven't specifically looked at a mirror on a XG350, but all of the mirrors I have repaired usually have a small set screw (slotted, allan or torx style) that secures the mirror to flat metal lug that was glued to the windshield. Loosen the screw and then remove the lug from the mirror. I suppose some may simply slip on and are secured with a spring clip. Those should slip out the slot on the bottom of the mirror with some force. Remember or mark the top and the side facing the driver of the lug so that it is oriented correctly when you glue it back onto the windshield. Repair kits with adhesive can be purchased at any auto parts store and most hardware stores. I've purchased them at Walmart and Kmart in the past. The kit will explain which solvent is best for cleaning the glass and glued face of the lug for the adhesive in the kit.
Old 05-25-2009, 06:58 PM
Joe Mc's Avatar
Ken, I'm sure once the plastic cover is removed the mount is similar. The problem, or question, is how does the cover come off to access the mechanical device holding the mirror in place? It's my neighbor's car and I don't want to mar the plastic cover prying it off. Anyone have an easy way to get the access cover off?
Old 05-25-2009, 07:08 PM
jsinton's Avatar
Banned
Give your neighbor the screwdriver and let him pry it off.
Old 06-12-2009, 07:51 PM
Joe Mc's Avatar
Thanks for your help.
Corgan
10-03-2006 05:01 PM
Corgan
08-19-2006 02:22 PM
Corgan
08-19-2006 02:20 PM
stiles88
03-30-2006 08:30 PM
toolazyforalogin
02-13-2006 12:15 AM
Quick Reply: Loose Rearview Mirror
