XG 300 Motor swap
Old 04-29-2010, 12:04 PM
RW-7's Avatar
Default XG 300 Motor swap
Hello, I have aquired a 2001 XG 300. It has a bad motor. Top and bottom. I am wanting to put in a good used motor from a wrecking yard, however I have a few questions first.
1. What motor should I look for What Vin code or engine sereis? D 8th didget? 3.0, 3.5?
2. What shoud the compression read on a good used motor for this car?
3. Has anyone on this forum done this and do you forsee any complications, or concerns?
Thanks, Rob.
Old 04-29-2010, 05:51 PM
Be sly and grab a 3.5 from another later XG or Santa Fe.
Most respects the engine is identical, just another 500cc. Verify all connectors and swap accordingly to drop back into chassis.
Old 04-30-2010, 10:30 AM
RW-7's Avatar
Was thinking of this, however I want it to be a direct swap. I am looking into the Sonata motor. Just would like some answers first. Like if the wiring and computer is the same?
Old 04-30-2010, 07:39 PM
Sonata is different engine family.. your choices is 3.0 (XG 300) or 3.5 (XG 350), as both is MELCO and use the 5 speed trans..
Sonata is 2.7 Siemens and 4 speed transmission.
Hopefully you were not refering to the 2006-present 3.3 engine, major disaster to install and wire.
Old 05-01-2010, 10:55 AM
RW-7's Avatar
Sounds good. I will be sure to keep it in the family..
Thanks for the input.
1955effie
10-17-2014 09:24 AM
rmonroe27
01-29-2012 07:52 PM
adkins
03-19-2010 10:01 PM
TSD_GS
09-19-2007 06:50 PM
Coppertop
08-23-2005 10:58 PM
Quick Reply: XG 300 Motor swap
