XGL 350 Check Engine light
I have a 2004 XGL 350 with about 82,000 miles on it. About a week ago, the check engine light came. No noticeable change in performance. I took it to a local mechanic who pulled two error codes off it: P1723 (transmission) and P0320 (ignition). Again, there's nothing that has changed in how the car runs. Yesterday, thelight wwent out for a bit, then back on.
Could this be a sensor/wiring issue rather than an actual problem with the trannie or ignition? |
Originally Posted by jammin7800
(Post 36327)
Could this be a sensor/wiring issue rather than an actual problem with the trannie or ignition? P0320 is an ignition speed input circuit and primary/secondary ignition coil circuit malfunction. |
Repair cost?
That's great. Thanks. Two things: 1) What does the repair involve and 2) how much should I expect to pay to get it taken care of?
