-   New Member Area (https://www.hyundaiforum.com/forum/new-member-area-4/)
-   -   03 santa fe 3.5 L spark plug replacement (https://www.hyundaiforum.com/forum/new-member-area-4/03-santa-fe-3-5-l-spark-plug-replacement-14507/)
davedmc66 Aug 7, 2014 06:40 AM
Hi all. New member here. Have gotten good info so I thought I would give some. There is a You Tube vid showing how to change the plugs in a 2003 3.5 L Santa Fe. In it she advises that you don't need a new intake gasket as long as the old one isn't broken. This is wrong. With all the work that's involved spend the $12 to replace it or it will seem as if you have some kind of emission control problem. Other than that it is good video.
TerryProTech Aug 9, 2014 05:58 PM
Good advice to go with a new gasket...They are certainly cheap enough and why risk having a leak after spending all the time to replace the plugs...
