04 xg350L
replaced spark plugs and wires and now car will not start. does anyone have the resistance specs for the coil pacs? I have power going to them, but need to check the coil pacs themselves. I also am getting fuel.
Check to see if there is spark to plugs
If it does then would check firing order |
No spark
Yes I checked the firing order after removing the intake again. I checked all my electrical connections, tested for power, which is leading me to my coil pacs. I am having trouble finding a good continuity check for the coil pacs, l like to diagnosis things before I just throw parts and money at it. |
Do you have power and grounds going to the coils?
What about the signal wire from the ECU? Here is how a coil works ... How to Diagnose and Test an Ignition Coil |
