08 accent not starting after
My 08 accent will not start, after replacing a head gasket, I know I have fuel I remove 3 of my spark plug smell gas on them also remove the fuel line off injector rail ,I FELT good pressure and spray of gas in my cover rag.New ngk sparks install,my ole spark has > 5K miles before my new head gasket.REMOVE the value cover to check my alignments belt and chain it seem okay. I took picture I have to figure out how to attach them to my post,all suggestion and help are welcome.
It doesn't take much to be off the mark and the engine will not start.
Worse is if the cams are 180 out of phase. It takes two revolutions of the crank shaft to make one revolution on the cam shafts Hopefully the number one piston is at top dead center and the cams were only a little off Sometimes people will miss read which marks need to be aligned Good luck |
Update checked out my cranksprocket timing position it on mark,rotate it 4 revolution 3x ,each time it made it mark. Now I need some help here ,how can apply 100ft/lbs of torque to that bolt without that pully moving, i watched many video's no one show how :confused::mad: %%&&&### they did it. I HAVE one idea can i put the car in park and lock it down,what do think:confused:.
https://cimg9.ibsrv.net/gimg/www.hyu...f1cf10236e.jpg https://cimg5.ibsrv.net/gimg/www.hyu...ecf1e7dc1c.jpg spot on 2nd Xs https://cimg3.ibsrv.net/gimg/www.hyu...1631b4b806.jpg spot on 3rd Xs https://cimg4.ibsrv.net/gimg/www.hyu...3729e0a21b.jpg what do thing is tis okay after 3x of 4 revolution each on crank mark? |
There are 2 marks that you need to line up when installing the replacement belt,
the mark on the crankshaft must line up with it's mark on the engine AND the camshaft gear must line up with it's mark on the engine, then install the belt making sure there is no slop in the belt on the side opposite the tensioner because when the engine turns clockwise the crank gear will pull on the belt to move the cam gear and skip a tooth if installed loose and that relationship must not change After you adjust the tensioner, you rotate the crankshaft at least 2 revolutions clockwise AND when the mark on the crankshaft is lined up to it's mark again, you make sure the camshaft gear is still lined up with it's mark. You can get the crank pulley bolt pretty tight after you install everything else and you can use one of the other belts to hold the crank pulley from moving. |
pully belt will be enough
Evening Hanky ,pully belt will be enough hold /apply my 100ft/lb on that nut. I WILL slip off belt for camshaft and rotate it clockwise to line up the marks and apply the belt back on and rotate 4 revolution to 2 for the camsprocket and tis will be okay? Would it be a good thing run the car for 2 minute to observe timing belt ,without putting on the rest of the belts, is tis okay?:)
If,,,,,,,,,,,,,,, the timing marks are off just one tooth, the engine will start and run, but not run right, Best to do the check without running the engine.
We try to do it RIGHT and do it ONCE. You must be very particular with this procedure. You are probably tired of working on this engine, so take your time once more, get it right and be done. Are you sure you know where both marks are on the "engine" that you are supposed to use to line the marks on the gears ? If not , let us know. |
2 Attachment(s)
I am sure of the mark position on the intake camshaft to it relationship of the exhaust camshaft.
Attachment 2158 ,is this what you referring too. |
In the photos I have provided can you tell what don't have right, i would be gratefully:)
Can you help out here?
You are showing pictures of a timing belt and asking questions about timing chain and double camshafts. Whats going on here? |
I can not see the timing marks for the cams. Sorry.
