| tms1983 |
May 19, 2023 07:47 AM |
2014 Accent Check Engine Light- p0650
Hey, all. Im new to this forum and do not have much car knowledge! I have a 2014 Hyundai Accent and the check engine light is not coming on anymore when I start the vehicle. I recently received a code of P0650. For some back context, I bought the car used from a dealer a little over a year ago (had only 100,000 miles), and the light WAS working as of about 6 months ago. When it first came on back in the fall, I took it in and found out it was a C02 sensor causing it to come on. The check engine light ended up going off on it's own before I fixed the sensor. I had the sensor replaced, and the light has never come back on since it originally went off on its own. Then this spring the car suddenly started acting like it was about to die after I drove it for a few minutes. I took it in somewhere for a full (and pricey) diagnostic test and they told me my exhaust manifold catalytic converter was clogged and needed replaced. I dropped over a grand to fix that. I wondered why the check engine light never came on when I was having the CC issues, so I started it up and realized it is not coming on at start-up- so its clearly not working (all other dash cluster lights are working). During a pricey diagnostic test at a mechanic I received the code P0650: Malfunction Indicator Lamp (MIL) Control Circuit Malfunction. It says under Verified Fixes: "Fix Description, Check Engine Light Bulb". The mechanic said they would need to run a 2nd diagnostic test (for an additional $125) to determine what is causing the P0650 code. That seemed a bit shady to me since the first code gives a lot of info already (but I know nothing about cars). My question is, where should I start when trying to get this fixed by a mechanic? Do 2014 Accents even have MIL bulbs that can be replaced or are they soldered to circuit wires? (I cant find any info on replacing the bulbs). Is it likely a bulb? A fuse? A wire? Remember the light just suddenly went off after having been on for a few weeks, so it worked at one time. Any info is helpful since I have already dumped way too much into a car I still owe a lot on! Thank you!
