Sponsored by:
Sponsored by:
2103 Sante Fe Sport 2.0T rear window issue
Old 03-19-2019, 10:31 PM
RTKinger's Avatar
Default 2103 Sante Fe Sport 2.0T rear window issue
Good evening. I have a 2013 Sante Fe Sport 2.0T and the driver side rear window will no go up or down with any of the switches. Does anyone know if this is just a motor issue or something else? All other Windows work fine with all switches.
appreciate any help. Thanks!!
Old 03-20-2019, 02:42 AM
You narrowed it down quite a bit.
What you might consider is to remove the interior door covering and actually verify power and ground are available for the motor.
Usually that window is not used that much and there is a good chance the motor and assembly are still good.
Old 03-20-2019, 10:42 AM
RTKinger's Avatar
Thank you for the reply. I plan on removing the interior panel and checking the connections this weekend. Hopefully something just shook loose. I checked the fuses and they are fine as well.
milehighbear
02-10-2019 08:28 AM
TPropis
03-08-2018 04:13 PM
dschrieber
10-01-2015 07:00 AM
heyitsomid
05-19-2011 02:38 PM
sameoldd5
01-29-2007 07:30 PM
Quick Reply: 2103 Sante Fe Sport 2.0T rear window issue
