Code PO441
Hello I'm getting a PO441 code vapor canister purge valve on my 2016 Tucson 2.0L I believe the solenoid is stuck open can someone tell me I if would cause any problems if I drove it for a couple of days before replacing...Thanks in advance
Hi Bruce, You didn't say if there were any symptoms.
I would think if the purge valve was stuck open , the engine would be running rich and throw a code for rich AND it would be eating gas. Soooo, checking what the code seemed to suggest , I would check if the fuel cap is all the way on or possibly not sealing completely. If that is all it was , correct that and after 2 trips it should allow the code to clear automatically. |
