Entourage Rear Wiper Motor
Has anyone changed a rear wiper motor for a 2007 Entourage? The fuses are fine, and the wiper fluid works for the rear window. I'm sure it's the motor at this point, but I'm having trouble accessing it. Any hints?
Before diving into removing the motor, suggest you verify power is getting to the motor through the plug and where the wire flexes.This can be done with a simple test lite or voltmeter.
Can this be done at the fuse panel located in the jack compartment? Or do I have to remove the tailgate panel?
We try to get as close to the motor as possible before removing anything.. You could have it at the fuse panel and lose it through the plug, or the wire from a lot of flexing from opening and closing the rear hatch. We always try to do the simple things first.
