No dash or center console lights
Hi I hope I can get some help. My dash, center console and shift indicator lights don't work. Checked all the fuses, and dimmer switch does nothing. It's a 2002 Hyundai Accent gs. Thanks if you can help.
Advise in a case like this is like a shot in the dark (pun intended). This may be caused by a failing ground connection.
i load 2011 ,I replaced the tail light fuse under bonnet, for the right hand side tail light . The fuse blew again so i removed the bulb and inserted an other fuse this time the illumination lights worked ok. I will try another bulb tomorrow .27/06 2019. the fuse box is under the bonnet on the back right as you look into the engine bay the fuse is marked r/h tail light.
Ray
Ray
