RADIO REMOVAL
CENTER FACIA PANEL REPLACEMENT
NOTE:
- When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
- Put on gloves to protect your hands.
1. Remove the crash pad side cover.
2. Remove the lower crash pad panel.
3. Remove the center gaurnish (A).
4. Loosening the crash pad center facia panel mounting screws.
5. After disconnecting the connector, remove center facia panel (A).
6. Installation is the reverse of removal.
NOTE:
- Make sure the connector is plugged in properly.
AUDIO ASSENBLY REPLACEMENT
1. Remove the center facia panel.
2. Loosen the screws.
3. Disconnect the audio connector and antenna cable, then remove the audio assembly (A).
4. Installation is the reverse of removal.
NOTE:
NOTE:
NOTE:
NOTE:
You couldnt ask for a better set of instructions...isnt the internet just great to find things on!
WheelBroker1
[IMG]local://upfiles/2409/8BA6ABE43A864F64B2FD49C62EFE42E2.jpg[/IMG]
WheelBroker1
zainecurtis
Apr 5, 2013 02:34 AM
flibottf
Jan 6, 2009 09:28 PM
