Chain/strap wrench
Hi folks,
Not sure if this is the right section as I couldn't see a "tools" section. Has anyone got any advice over the difference between a chain oil filter wrench and a strap oil filter wrench? Chain: http://www.machinemart.co.uk/shop/pr...-filter-wrench Strap: http://www.grainger.com/Grainger/RID...p-Wrench-4CW49 Can't decide which would be better. For nearly 14 years, I have managed without, but have decided to buy one. I like the idea of a strap wrench as it seems more versatile and could be used on pulleys and other items without fear of damaging them. Any advice? |
Neither of those. Forget the chain and if you want a strap wrench, get metal or rubber, not nylon. These are much better choices:
Metal: http://www.homedepot.ca/wcsstore/Hom...df993083_4.jpg Rubber: http://www.northerntool.com/images/p...1501539_lg.jpg Plyers: http://a1toolsales.com/images/oil%20filter%20wrench.jpg Compression "socket": http://toolmonger.com/wp-content/upl...r%20Wrench.jpg http://valuesetters.com/vendor_10_pr...ges/648659.jpg http://www.1130cc.com/gallery/files/.../p0034603x.gif |
Thanks for the reply.
Why not the nylon type? I was after something versatile and strong that I could also use to hold pulleys etc if I needed. I actually have a boa type rubber wrench, but never used it as I considered it too weak for anything and a waste of money. |
I don't believe they grip as well as the steel straps (with little spikes) or the rubber straps.
cheers for that. Always good to know before you buy.
