Clutch Problem in I20 Magna Opt Diesel 2012 model
Hi,
I now replaced my clutch master cylinder and slave cylinder but still I am facing issues in gear shifting i.e when the clutch is fully floored only,I am able to shift gears.I am unable to shift gears when the clutch is half pressed or not fully pressed.Do I need to replace the clutch plate in this case?? Also,I would like to know if the brake and clutch both use the fluid from same reservoir or from respective master cylinders?? Please advise... Thanks in advance, Debasish |
Hi,
