Clicking/Knocking noise when braking?
I have a 2004 Hyundai Getz, whenever I brake mostly when the car is coming to a stop ) there is a clicking / knocking kind of sound coming from the drivers side but sometimes I feel like its coming from both. (You can hear it when you start braking at a faster speed but don't hear it straight away and it gets a lot louder when you're slowing down to a stop. I have had the brakes checked and there is nothing wrong with them apparently. I'm just coming on here to see if anyone else has had a similar problem and/or know a reason for it.
Thanks! |
Do you know if anything else like the CV joints were checked? If you turn the steering wheel sharp to the stop in both directions and back up, do you hear any noise then?
That puts some stress on the CV Joints and if not good you may hear a clicking noise. |
i think you are directing him a right way. the things you are explaining are quite reasonable.
Thanks for your support.
Most times when we do not reply with addl suggestions, it is because the process or info suggested is worthwhile and pretty accurate. Thanks again. |
