Suspension Talk about your suspension within.
2011 Sonata Turbo - Struts recommendation
Old 02-23-2019, 10:53 AM
Tony Smithe's Avatar
Default 2011 Sonata Turbo - Struts recommendation
Hey!
Looking for Strut replacement recommendations for 2011 Sonata 2.0T. I'd like to use a quick strut if possible and do the work myself, as the dealer quoted 1K for just the fronts.
Old 02-24-2019, 06:53 AM
allegretto's Avatar
I have had good experience with Monroe strut assemblies.
https://www.rockauto.com/en/catalog/...assembly,15174
Pay attention to the production date of your car.
Old 02-24-2019, 04:04 PM
Just a reminder,,,,,,,,,,,,,,,
After strut replacement a front end alignment is required to prevent questionable performance and tire wear problems.
Old 02-24-2019, 09:24 PM
Looking into a bit further, I believe I have the Sport Suspension - looking at the site, it indicates these won't work with sport suspensions..
thoughts?
Old 02-25-2019, 07:05 AM
allegretto's Avatar
thoughts?
They should work with a sport suspension but the ride will be softer.
Get the dealer prices for the individual parts that make up a strut: Strut (damper only), strut mount, dust boot, isolators (rubber rings for the springs), springs.
An independent garage can reassemble a strut for you at a much lower cost than the dealer is asking.
Also check with the major auto parts stores for Monroe, KYB, and maybe Gabriel brands.
Old 03-04-2019, 11:25 PM
MrKnowitall's Avatar
Get the oem part numbers for the struts to cross reference the aftermarket equivalent. The sport suspension doesn't just have a different dampening rate it sits slightly lower due to a difference in spring height meaning piston stroke of the cartridge is different. You don't want to mix them up as it will cause it to be a stiff ride and potentially cause damage. 2011 models are even trickier for aftermarket front suspension parts because the whole thing was redesigned mid model year. Early production used a full front subframe and late production use the now common K frame found on all new hyundais. The struts for each are not interchangeable
ninja_hamster
02-18-2012 09:40 PM
dichayer
09-28-2011 04:56 AM
snoty
12-10-2009 10:42 AM
bert
10-24-2009 08:22 AM
excaliboar
07-21-2008 10:51 AM
Quick Reply: 2011 Sonata Turbo - Struts recommendation
