Suspension Talk about your suspension within.
Rear Strut Banging on 2001 XG 350
Old Dec 4, 2008 | 10:23 PM
teachdqs's Avatar
Default Rear Strut Banging on 2001 XG 350
My 2001 XG 350 makes a banging noise that has been suggested as the rear struts. This occurs when the car goes over bumps. I just replaced the rear tires which were badly cupped and made a howling noise while driving at highway speeds.
Are these struts prone to developing clunking problems with the strut mount? Can they be replaced by DIY or are specialized tools required?
Thanks for your help.
Old Jan 2, 2009 | 08:48 AM
Skrag55's Avatar
Default RE: Rear Strut Banging on 2001 XG 350
The rear upper strut arm is connected to the strut housing by 14mm bolts. The threads on the strut housing are welded in place these usually break causing the upper arm to move around when going over bumps. The only special tool you will need is a spring compressor.
Old Jan 2, 2009 | 09:39 AM
Are the struts original? How many miles are on the struts? If they are original, it's time to replace the 8 year old struts.
Old Jan 2, 2009 | 02:37 PM
jsinton's Avatar
Banned
If the tires are cupping, then probably the struts are bad and need to be replaced. Replacing the struts is a good time to check to see if any of the mounting bolts are loose, which is probably the cause of the banging. Skrag55 is correct, it's not a big deal to replace them yourself, you just need a spring compresser. I think Autozone will lend the spring compressor for free if you buy the struts there.
MFF
Dec 4, 2008 10:31 PM
teachdqs
Dec 4, 2008 10:30 PM
fintile
Apr 5, 2008 11:27 AM
shawnboy
Dec 30, 2007 02:23 AM
vtbob
Nov 19, 2006 12:56 PM
