Wheel size for 2010 Hyundai Elantra
Hi,
Got a stock steel rim 15" and planning to buy an alloy one to replace this steel rim and use the same tire size 19565R15. What are the acceptable offset, wheel width and center bore that I should be looking at aftermarket wheels? Any other parameter I should consider? Thanks! |
Aftermarket Wheels
Most wheel/tire stores have the proper size and offset wheels to fit your '10 Elantra. All you have to do is tell them what kind of car it is and what year and they can log in the info and all the proper wheels that will fit correctly will pop up. Pep Boys have a good selection at a great price. Upgraded the factory alloy 16's with an aftermarket 17's alloy with factory size Dunlops. Fits perfect.
Personally, I think Pep-Boys are good for little things like oil and bulbs but I wouldn't buy wheels there. I'd suggest TireRack.com or DiscountTires.com
