Front Brake Wear
Old Mar 17, 2006 | 02:17 PM
rraahh's Avatar
Default Front Brake Wear
I have a 2005 Elantra with front disk/rear drum brakes. It has 15000 miles on it. The dealer has replaced the front pads and rotors 3 times all rdy, and it needs them AGAIN! They wont do it now.
The front brakes start makeing a grinding noise as if its metal to metal BEFOR the pads are gone.
But within another 500 miles or less, the right front IS metal to metal. Always the right front is the most worn. But signs of excessive wear on the left as well. ANY help would be appreciated.
The rear brakes still look almost new. Thanks much. Also, the first time They repalced the pads/rotors the brake lights started coming on randomly. Like in the middle of the night parked in the driveway. They replaced the brake pedal switch saying it was too sensitive.
Old Mar 17, 2006 | 06:57 PM
flave1's Avatar
Default RE: Front Brake Wear
this sounds like the brake pedal needs adjusting. did the dealer check to see if your brakes were binding after a few miles? just check if you have any free play in your pedal before the brakes are applied.
Old Mar 17, 2006 | 07:28 PM
rraahh's Avatar
Thank you, I'll have that done asap.
Old Mar 20, 2006 | 03:23 PM
poacher's Avatar
I was also wondering if one side is wearing considerably faster, you may have a bad caliper.
hyse09
Oct 25, 2025 04:43 AM
06tusconNY
Sep 20, 2007 09:32 AM
wsteinhauer
May 16, 2007 03:53 PM
kuyi84
Oct 22, 2006 01:14 AM
SEABUZZARDS
Sep 28, 2006 10:29 AM
