Slow Fuel Fill Problem Diagnosis
#33
Can any body tell me were the vapor vent valve is my 00 sonata is throwing up the evap system light and I can't afford to have the mechanic take his time trying to do a smoke test and funding the leak. I did a visual inspection of the lines they all look fine and no rust build up anywere if it was my charcoal canister it would throw up a different code but its nit so I'm pretty its the bait bent native but I can't find out in your diagram
#35
01 sonata fueling problems
iv ebeen having problems fueling my sonata and i took it to get fixed and they replaced the canister, close valve and some other valve. However, i still can't put more than a few cents at a time in. They said the charcoal had come out of my canister and they tried to clear out any from the fuel line that goes to the gas tank. I don't know what else to do and why the probem still persists. do i need to get a new gas tank (which is the final solution that they recommend)? they said the charcoals mikght have gotten into the tank itself so it would need replacing, is this true? please help.
#36
For what it's worth: on my Accent, and probably on your Sonata, there's a 1/2" rubber line that runs from the front of the charcoal canister to a steel line that goes to the top of the fuel fill line. This line is held on by small compression clamps. With a small pair of channel locks you can remove this clamp and dump the charcoal pellets out of this line. I went through this exercise before every fill up for 8-10 fillups, and the problem finally went away. I think it's worth a try before you buy a new gas tank. Again, the repair shops are grasping for straws, at your expense. What year is your Sonata?
#37
#38
Good luck KBurch! The shop is in the "swap parts" mode. I don't fault you for getting it fixed right ... that's the right thing to do. That's the ONLY complaint I have with my car. The charcoal canister design is a poor one that even the experts don't know how to fix.
#39
picture of charcoal filter?
this post is great but i have NO experience in repairs & am clueless. Someone told me that its easy 2 just check the charcoal filter & im wondering if there is a pic of it & where exactly is it located...my accent also is shutting off after 2 gallons and i can barely get it 2 take half a tank....thanks
#40
This post provides quite a few pictures and descriptions of the charcoal canister assembly. To troubleshoot takes only minimal skills, however if you aren't mechanically-inclined I woiuld take it to a mechanic. And take heart! I dumped charcoal pellets out of my vent line for 10-15 fillups, and the problem finally went away. The fuel fill problem is the only complaint I have with my '02 Accent. Other than that, 188,000 miles and going strong, with no major repairs. Good luck.
