RESET check engine light?
Old 03-24-2007, 01:53 AM
carlibobarli's Avatar
Default RESET check engine light?
How do you reset the "Check Engine" Light. I've heard that even if you perform corrective maintainance on the car, that it won't necessarily turn the warning light off on its own.
Old 03-24-2007, 11:58 AM
Default RE: RESET check engine light?
Hi. I have a lot of issues with my lights...I have heard that you disconnect the battery, wait a few minutes, then plug it back in and restart the car. But I do not know if this works. Your best bet is to get an OBDII scanner, from Walmart or an auto store, read the code, and if it isnt anything to worry about erase it. It is true that the light wont always turn right off when the problem is fixed because the faulty code is stored in the computer until someone (or something) erases it. The scanners are 50 to 80 bucks, or you can take it to a garage and have them turn it off.
Old 03-24-2007, 03:34 PM
seiken's Avatar
just disconnect the battery, go make yourself a sandwich, then hook in back up.
(randomness) also, check your gascap, if its not on all the way it will throw a code, so if it goes on randomly consider checking that before you start tearing your engine apart.
Old 03-24-2007, 08:23 PM
WheelBroker1's Avatar
I use my OBII scanner to turn off the engine light after I ve fixed the problem, problem is that since 2004 when i bought the Sonata New , I've only had one engine light come on..loose fuel cap...
WheelBroker1
Old 03-24-2007, 10:57 PM
seiken's Avatar
yeah, its not like im not saying an obd scanner isnt better, it just cost money... i cant speak for everyone, but there is a reason i bought a ten thousand dollar car instead of a thirty thousand dollar one, i got no extracash to buy a tool i may use once or twice.
im only saying that disconnecting the battery is a low cost alternative
xcpa
04-12-2013 03:13 PM
elkarshofy
08-04-2012 05:56 PM
jordanwake
02-06-2011 08:13 AM
hycustomer
05-08-2008 07:12 AM
tabsonata
11-25-2007 08:51 PM
Quick Reply: RESET check engine light?
