2011 Elantra Remote lock not working
Old 02-15-2011, 06:34 PM
tringo's Avatar
Default 2011 Elantra Remote lock not working
Hi,
I just picked up my new 2011 Elantra yesterday, it had 35km on it.
Already I'm having a problem where both key fobs do not unlock/lock the car. BUT, when I open the car with the key manually the remote's begin to work.
The remote works there on, until the car is left for a period of time (I think in most cases more than an hour). After this the remote's stop working again!
Also, after I start up the car each time the radio and clock have wiped everything from record.
Any thoughts?
Old 02-15-2011, 10:31 PM
WARRANTY -- Take it to dealer and let them deal with it
Old 02-16-2011, 01:15 AM
bigdogbitu's Avatar
Default Remote
There is a fuse panel in the dash just above the hood release. Take off the panel and look to see if a yellow switch is in the "OFF" position. If it is off, take a flat head screwdriver and flip it to the "ON" position. This should have been done by the dealer. It is a mode switch that turns off many of the electronics when the car is not used during shipment. It is mentioned briefly in the owners manual and has caused many of us some grief. The electronics will work briefly then stop working when the car is not used for a short time. This problem has been discussed on other forums for months.......................
That switch will fix all your electronics issues, fob, radio, clock.................Good luck with your new Elantra!
2011 Elantra Desert Bronze with Navi
2005 Acura TL
1989 Mercedes 300E
Old 02-16-2011, 10:33 AM
tringo's Avatar
Great, thanks a lot!
I opened up the fuse box and the switch was indeed 'Off' I will be stopping by the dealer today to get them to switch it back on. and hopefully they remember to this on future sales too.
Old 02-16-2011, 02:31 PM
bigdogbitu's Avatar
Default Yellow Switch
Many dealers across the country were forgetting to move the switch to the "ON" position when prepping the car. My dealer was unaware of the issue until I told them about it back in December. The switch can still be a good idea if you plan to store your car for a period of time and don't want the electronics to drain your battery. It simply reduces the power drain when the car in not in use.
mickmo
11-06-2012 01:40 PM
nester521
05-11-2011 11:04 AM
anita
04-27-2009 07:18 AM
muhdpedeh
12-22-2008 02:16 PM
Logik
06-06-2006 10:54 AM
Quick Reply: 2011 Elantra Remote lock not working
