About to change the spark plugs
Old 06-16-2012, 05:15 PM
uhlan's Avatar
Question About to change the spark plugs
I am About to change the spark plugs on my 2002 Sanat Fe V6. It looks rather tedious but not really difficult. I see pretty clear instructions at the following link Hyundai Santa Fe Spark Plug replacement on a V6 Cyl
One point puzzles me. They claim that:
"Remove the three rear plenum tie down bolts. The left one you can see from the left side, the right one is right below the throttle cables about an inch from the right edge of the plenum, and the center one is under the main throttle cable bracket. DO NOT REINSTALL THE CENTER BOLT WHEN REVERSING THE PROCESS. Without the center tie down bolt you MAY be able to skip steps 3-8. I didn't check so this is still unknown."
Can any one provide some clearer details on the reinstall comment?
If I do just install will I merely have a longer reassembly process or will I be in any sort of trouble?
Ed1976
10-22-2013 08:31 AM
zachunderwood
10-25-2009 08:18 PM
joe
01-17-2008 07:35 AM
Boomer
04-23-2006 03:36 PM
joe
10-24-2005 01:26 AM
Quick Reply: About to change the spark plugs
