How to remove the door panel fo santa fe 2008
Old 03-06-2009, 01:11 AM
pouriania's Avatar
Default How to remove the door panel fo santa fe 2008
Hi, I have a hyundai santa fe 2008 and I wanted to open the front and rear door panels to install new wires, does any one have any picture or manual for it?
Thank you.
Old 03-06-2009, 07:21 AM
Front Door Trim Replacement
NOTE:
- Take care not to scratch the door trim and other parts.
- Put on gloves to protect your hands.
1. Remove the quadrant inner cover (A).
2. Remove the inside handle cover (A).
3. Loosen the door trim (D) mounting screws. Release the clips that hold the door trim, then remove the door trim by pulling it upward. Disconnect the power window switch connector (A), power mirror connector (B), and door courtesy lamp connector (C).
4. Installation is the reverse of removal.
NOTE:
- Make sure of connectors is plugged in properly and each rod is connected securely.
- Make sure the door lock and opens properly.
Rear Door Trim Replacement
1. Remove the inside handle cover (A).
2. Loosen the door trim (B) mounting screws. Release the clips that hold the door trim, then remove the door trim by pulling it upward. Disconnect the power window switch connector (A).
3. Installation is the reverse of removal.
NOTE:
- Make sure the door locks and opens properly.
Old 09-08-2009, 12:52 PM
RedKayak's Avatar
Can anyone provide more specifics on removing the quadrant inner cover? I removed the back door panels with no issue to replace the horrible stock speakers, now I need to get the front. I'm not sure which way to pull cover to release whatever is holding it in place. Thanks...
Old 09-08-2009, 01:41 PM
It just pulls off.
dprado
09-05-2015 06:03 PM
nwu2012
06-25-2012 02:36 AM
pcarvallo
02-15-2012 08:09 AM
mariotest
03-01-2010 07:52 AM
smileyx4
04-06-2005 04:50 PM
Quick Reply: How to remove the door panel fo santa fe 2008
