Ticking in engine normal?
Do you mean it ticks when the motor is at idle, or when the motor is turned off.
If you're talking about the "tick" after you turn the motor off and it's cooling off, THAT'S NORMAL!. My Sonata used to do that. Nothing to worry about, the metal parts are contracting. Probably the catalytic converter cover contracting was my impression.
Both my 2008 V6 Sonata and my daughter's 2009 I4 Sonata have a very noticeable injector tick at idle. The I4 is louder than the V6, I think the larger engine cover on the V6 does a better job of baffling the noise. I suspect this what you are hearing. Judging from the number of folks asking about this "idle tick" on various Hyundai-related forums, it appears to be a pretty common occurrence.
