2007 Sonata which Tire Size to Buy
Old 03-26-2009, 01:31 AM
Veneetraj's Avatar
Default 2007 Sonata which Tire Size to Buy
Hello All,
Thank you very much for your continued support, I have another question for the forum.
I have a 2007 Hyundai Sonata 2.4 liter with aluminum alloy wheels which has Michelin 215/55 R17 tries.
I am located in California and I am looking to buy just regular tires for my Sonata however my question is that what size should I buy? There are six variants available
1. 215/50 R17
2. 215/55 R17
3. 215/60 R17
4. 215/65 R17
5. 225/50 R17
6. 225/55 R17
7. 225/60 R17
8. 225/65 R17
I would understand that 215 and 225 is the width of the tire but if I go for a wider tire will it interfere with my wheel arches of my car? Also if I stick with 215 tires then can I opt for either 50/55/60/65.
My colleague indicated to me that the engine life of the car increases if the tires have a larger diameter namely 215/65/R17, he also indicated between 215/65/R17 and 215/50 R17 it will be better to opt for 215/65/R17 as the engine will be spinning at a lower RPM for the same speed which in turn will marginally affect engine life and mileage. He did say that there will be a speedometer error which will have to be compensated
Is there any brand of tires which is better than the rest?
Any advise will help me out.
Regards
Veneet
Old 03-26-2009, 08:14 AM
Your original 215/55 R17 tries are 26.3" tall.
215/50 R17 tires are 25.5" tall and will cause an speedometer error of 3.0%. (Unacceptable)
215/60 R17 tires are 27.2" tall and will cause an speedometer error of 3.3%. (Unacceptable)
215/65 R17 tires are 28.0" tall and will cause an speedometer error of 6.7%. (Unacceptable)
225/50 R17 tires are 25.9" tall and will cause an speedometer error of 1.5%. (Acceptable)
225/55 R17 tires are 26.8" tall and will cause an speedometer error of 1.8%. (Acceptable)
225/60 R17 tires are 27.6" tall and will cause an speedometer error of 5.2%. (Unacceptable)
225/65 R17 tires are 28.5" tall and will cause an speedometer error of 8.3%. (Unacceptable)
Personally, I would go with the 225/55 R17 tires.
As far as brand, I've always had good experience with Kumho tires.
Old 03-26-2009, 11:42 AM
jsinton's Avatar
Banned
Regards
Veneet
Engine life will not be enhanced if you increase the tire size. It still takes X amount of force to propel your car at Y speed. Better off driving the car slowly and change the oil on time.
I recommend buying the stock tires as this is the tire that was designed for the car. It's a crap shoot to second guess what might be a better size.
Nova is right, Kumho is a great balance of price and performance. The best Kumho tire is excellent, even for my Lexus. You could buy Michelins, but they cost 33% more and are not any better.
Explore your tire options on tirerack.com, the largest seller of tires in the world.
Old 03-26-2009, 03:44 PM
Veneetraj's Avatar
Hello Nova and Jsinton,
Thank you very much for your responses.
will stick to the origninal size of what I currently have.
Regards
Veneet
funrunner
02-23-2011 08:05 PM
mjb457
11-20-2010 08:23 AM
chuckinnc
04-21-2009 01:05 PM
jholicky
11-25-2008 11:31 AM
funrunner
07-17-2008 09:54 PM
Quick Reply: 2007 Sonata which Tire Size to Buy
