Windshield Washer Reservoir Replacement
Old 08-15-2010, 11:34 PM
atholon's Avatar
Default Windshield Washer Reservoir Replacement
Hi,
How are you supposed to remove the reservoir for windshield washer fluid? Mine has a crack in it and I need to replace it.
Thanks,
Old 08-16-2010, 07:32 AM
What year?
Old 08-16-2010, 07:43 AM
I checked your other post and I see you have a 2002. Next time, please tell us what year or any other important info so we don't need to search for it.
REMOVAL AND INSTALLATION
1.Disconnect the negative(-) battery terminal.
2.Remove the front bumper cover. (see below)
3.Remove the washer hose and the washer motor connector.
4.Remove the washer reservoir after removing 2 bolts.
5.Installation is the reverse of removal.
1.Loosen the head lamps, disconnect all connectors, and remove the head lamp.
2.Remove the 6 mounting clips on the upper bumper and 2 clips in the inner bumper.
3.Remove the mounting bolt and nut in the bumper side.
4.Raise the vehicle, remove the clip and screw from the lower member, and remove the bumper cover.
5.Remove the bumper stay.
6.Installation is the reverse of removal.
Old 08-21-2010, 07:35 PM
atholon's Avatar
Hey, thanks for the instructions! It was an '02.
Luckily we didn't end up needing to take the bumper off. Once we got it jacked up the tire dropped down low enough that we could pull the resevoir out through the wheel-well.
Old 12-27-2016, 05:36 PM
olevet's Avatar
Default New member here, Grand daughter has a 2015
Sonata what are the steps in changing the reservoir on it? Thanks
jclhf
11-20-2011 07:37 AM
JSAD10
12-27-2007 10:38 PM
pneandy
06-06-2007 11:16 AM
cmkerns
02-01-2006 07:38 PM
Quick Reply: Windshield Washer Reservoir Replacement
