Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
need help removing trim below head unit
Old Jun 26, 2009 | 08:55 PM
BrianColo's Avatar
Default need help removing trim below head unit
After romoving the factory head unit from an '08 Sonata GLS, I want to route a cable into the small compartment below the heat/AC controls. How do I remove the panel so I can get access to the rear of this compartment? I've removed the two screw (the ones under the trim strip), but there seems to be other places where it is attached.
Thanks, Brian
Old Jun 27, 2009 | 11:17 AM
REPLACEMENT
CRASH PAD CENTER PANEL REPLACEMENT
1.Remove floor console assembly.
2.Remove the center garnish (A).
3.Remove the glove box.
4.Remove the center facia upper panel.
5.After loosening the crash pad lower panel mounting screw, then crash pad lower panel (A).
6.Installation is the reverse of removal.
CLUSTER FACIA PANEL REPLACEMENT
- When prying with tip screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
- Put on gloves to protect your hands.
1.Tilt the steering column down.
3.After disconnecting the trip sensor connector (A), remove the cluster facia panel (B).
4.Installation is the reverse of removal.
- Make sure the connector is plugged in properly.
CENTER FACIA PANEL REPLACEMENT
1.After disconnecting the connector (A), remove the center facia panel (B).
2.Installation is the reverse of removal.
LOWER CRASH PAD PANEL REPLACEMENT
1.Remove the center garnish.
2.Loosening the crash pad lower panel mounting screw.
3.After Disconnecting the connector(A), remove lower panel (B).
HEATER CONTROL UNIT REPLACEMENT
1.After disconnecting the connector (A), remove the center facia lower panel (B).
2.Loosening the heater control mounting screw, remove heater control unit (C).
3.Installation is the reverse of removal.
BrianColo
Oct 6, 2011 10:09 PM
Tyrod
Sep 13, 2008 09:01 PM
rdiehl
May 12, 2008 08:07 AM
sooslik
Dec 28, 2006 10:53 AM
Excel88
Aug 14, 2006 03:51 PM
