Engine & Internal Chat about beefing up your engine's insides here.
throwout bearing ?
Old Dec 20, 2005 | 10:05 PM
nytelush's Avatar
Default throwout bearing ?
does anyone know if you need a special tool to remove the throwout bearing from the pressure plate on a 2002 elantra 5 speed or if i just need to replace the whole clutch
Old Dec 21, 2005 | 05:07 PM
whiterice's Avatar
Default RE: throwout bearing ?
no the bearing just basically snaps into place and should pull out with a little bit of finesse. i would change the clutch if i was already that deep into it plus its only about 100 for a oem kit. also check the shifter fork (which slides through the throwout bearing) they tend to wear after a while causing the bearing to slide off and misalign. use plenty of grease on contact spots when reinstalling. good luck
Old Dec 29, 2005 | 09:57 PM
myhyundairocks's Avatar
a pair of snap ring pliers and a really big pry bar usually works for me on these
jas238
Dec 28, 2009 06:36 PM
jaycman
Oct 27, 2009 10:32 PM
William Young
Nov 7, 2006 07:31 PM
kittbailey
Dec 27, 2005 11:13 AM
miatawnt2b
Nov 4, 2005 04:35 PM
