1995 LANTRA AUTO FAULT
Old Apr 21, 2005 | 02:55 AM
LYAL's Avatar
Default 1995 LANTRA AUTO FAULT
Hi I have a 1995 Lantra GLS auto 1.8. I had the auto rebuilt and since then it intermittenly has very harsh changes mainly under low load. The problem is less if I plant it. Have been back to the rebuilder and Hyundai with no resolution. Now it will do it when the air con cuts in but the revs do not appear to be dropping enough for it to drop out of drive although I susspect this is the additional problem.
Sny ideas????????
Old Apr 21, 2005 | 09:33 PM
Patrick's Avatar
Administrator
Default RE: 1995 LANTRA AUTO FAULT
it sounds like when the trans was rebuilt, it was done so too tight internally, so the bands inside slam together instead of easing together..
Old Apr 22, 2005 | 10:31 AM
duke's Avatar
did you check the ground connection on the tranny yet ?????
Metsavend
Aug 22, 2011 10:23 PM
paulevof2
Jan 1, 2008 03:27 PM
Soundpimp
Sep 13, 2007 03:56 AM
nixie360
Aug 4, 2007 06:41 AM
john199
Dec 3, 2004 12:32 PM
