2005 hyundai elantra automatic
Old Dec 18, 2020 | 07:37 AM
Coye Denny's Avatar
Default 2005 hyundai elantra automatic
2005 2005hyundai elantra replaced input and output speed sensors now I don't have high gear not shifting right
Old Dec 18, 2020 | 07:59 AM
Hi Denny,
Can you bring us up to date?
What was the original problem?
Jumping to conclusions and replacing parts, especially good parts, can get expensive and disappointing.
From my experience, the problems from malfunctioning sensors is about equal to "poor electrical connections" which increases with age.
Old Dec 18, 2020 | 08:22 AM
Coye Denny's Avatar
I replaced input and output speed sensors because. The transmission started revving up instead of shifting properly .
Old Dec 18, 2020 | 08:36 AM
Coye Denny's Avatar
Default coye denny
It was not shifting properly revving up between gears and tacind high
Old Dec 18, 2020 | 09:10 AM
Coye Denny's Avatar
Default hank
It was revving high between gears not shifting right I checked all plugs except internal transmission. Changed fluid used correct type so then I replaced speed sensors
Old Dec 18, 2020 | 09:11 AM
Coye Denny's Avatar
Default hank
Old Dec 18, 2020 | 12:35 PM
I'm not too sure speed sensors are the problem.
Sometimes valves in the trans valve body cause these problems, and so can poor line pressure to apply clutches. If it is happening with different speeds and gears , it may be a pressure regulation problem. It is rare for all clutches to go bad all at once , except if the fluid became contaminated.
Old Dec 18, 2020 | 07:47 PM
avisitor's Avatar
Would have tried a drain and fill to see that would improve things
Coye Denny
Dec 18, 2020 07:31 AM
Bcgiceman
Aug 30, 2020 08:42 PM
Brandon Martone
Aug 7, 2018 10:43 AM
burner73
Aug 5, 2008 10:20 AM
elantra1
Dec 8, 2005 06:38 PM
