-   -   2013 Elantra P0016 & P0340 issue (https://www.hyundaiforum.com/forum/general-tech-help-5/2013-elantra-p0016-p0340-issue-17083/)
bpt513 May 18, 2018 02:44 PM
Hi all,
I have a '13 Elantra GLS 1.8. Recently, the engine light came on and the P0016 code came up for camshaft issue. I took it to a mechanic friend and he thought the sensors were good so I went ahead and replaced the intake VVT. That didn't work and a day later car would not start. I then replaced both cam sensors. Now the P0016 is gone but new P0340 came up. These are brand new OEM sensors. I even put old ones back in and still 340 code. I get power to the sensors.
I then replaced exhaust VVT and still 340 code and won't start. I've read this engine has a maintenance free timing chain that doesn't need to be replaced.
Anything else I can try? I don't want to take to dealer if possible.
thanks
R&R Automotive Dec 28, 2020 12:02 AM
Originally Posted by bpt513 (Post 54352)
Hi all,
thanks
Hello, Did you ever resolve the issue with your P0016 code on your Elantra?
Prabhjot Nov 1, 2022 12:05 PM
Solved
Hey have same car same issue please tell if you found the issue ?
hanky Nov 3, 2022 11:24 AM
You might be a little late since the post was dated Dec 2020.
