97 tiburon problems
Old Aug 6, 2005 | 01:41 AM
MegaMak's Avatar
Default 97 tiburon problems
my car is having similar problems to the guy who posted about his 98 bogging down and having rough idling/stalling. my car will randomly shut off while idle at lights, and sometimes while driving ill lose throttle response. to counteract this, i had to set my idle manually to have it sit around 800-1000, and its turned wide-open. i checked my sensors, tps is fine, had a problem code with idle control and 1st O2 sensor reading wrong. i recently did timing belt, plugs, wires, coil pack, cleaned fuel injectors.
any help would be appreciated, thanks.
Old Aug 6, 2005 | 05:49 PM
pure performance's Avatar
Default RE: 97 tiburon problems
its your tps or tps wires and connector most likely
Old Aug 7, 2005 | 07:26 AM
MegaMak's Avatar
thanks, ill check those out asap.
Old Dec 30, 2006 | 04:41 AM
dale3.14's Avatar
Default RE: 99 tiburon problems
My 1999 tiburon idles between 1500-2500 rpm's when I put in the clutch. When I come to a stop the idle sticks at 2000-2200 rpm's. Tonight the check engine light came on steady. Can you help me?
picard25
Mar 14, 2017 10:09 AM
laulaubell
Mar 26, 2012 07:50 AM
TonkaTruckMan
Feb 18, 2010 09:12 AM
mmenzies70
Nov 6, 2009 09:31 AM
mibellatortuga
Jul 12, 2006 09:34 PM
