Bumper Stickers
Old Jun 3, 2007 | 01:17 AM
Elantra's Avatar
Default Bumper Stickers
Hi all, I recently purchased a used car, and the previouse owner plastered bumper stickers all over the rear end. My question is this: What is the best way to remove them without damaging/removing the paint? The stickers are on the plastic bumper, and on the metal trunk lid. I thought about using a straight edge razor blade, but am concerned with ruining the paint. Any suggestions would be much appreciated. Thanks.
Chris
Old Jun 4, 2007 | 08:26 AM
Doohickie's Avatar
Default RE: Bumper Stickers
You're right, the razor blade is a bad idea. I would try a combination of Goo Gone, Bug & Tar remover, and maybe trying to get under the stickers with a nylon spatula to avoid getting into the paint. Once you've gotten as much as you can off, use a clay bar to take off the last little bit of any residue, and if if the clearcoat is marred, use some Meguiar's Scratch-X to smooth it out. Scratch-X needs pressure and heat to work, so if you use it, rub it very hard and fast (take out your frustration at the previous owner by pretenting the bumper is his face or something!) Finally, apply a good wax to protect the cleaned area.
Old Jun 5, 2007 | 05:42 PM
Elantra's Avatar
Thanks for the advice Doohickie. I have heard of a few of those products that you mentioned, but I am unfamilaire with a clay bar, and the use thereof. Any advice where I can learn more about a clay bar before I get in too deep, so to speak? Thanks again. Chris
Old Jun 5, 2007 | 07:59 PM
Doohickie's Avatar
One clay bar product: http://www.meguiars.com/?auto-detail...rface-Clay-Kit
These typically run $20 or less at auto parts stores. It comes with a spray lube/cleaner; you spray a little area, then wipe the bar on it. It takes stuff off the surface but will not get into the clear coat.
Old Jun 10, 2007 | 02:42 PM
Elantra's Avatar
Doohickie, I had the car at my Mecanic this week doing the Safety and Emmisions. I asked him about the claybar, but he had never heard of it either. He suggusted I try a sticker remover you buy at any auto part store. He said it comes in a spray can, and you just spray it on the sticker, and it makes it bubble and easy to remove. Have you ever heard of such a product? If it works? Any experience? Thanks again. Chris
Old Jun 10, 2007 | 09:54 PM
Doohickie's Avatar
I don't know, but as long as it's safe for automotive finishes it's worth a shot. Just make sure that it won't hurt your paint. If there's any doubt, maybe spray it somewhere where people can't see (underneath or something) before using it on a visible area.
srcbeast
Sep 10, 2007 01:12 AM
chirc
Mar 3, 2007 02:44 PM
lowglide88
Apr 12, 2006 10:24 PM
2loud2k2xd
Mar 18, 2006 11:08 AM
JSqualo621
Jan 13, 2006 03:19 PM
