Cant find scanner connector under dash
Old Jan 20, 2009 | 08:43 PM
Rhondas's Avatar
Default Cant find scanner connector under dash
I have been searching 2 days now to find the connector for my hand held scanner under the dash by the clutch pedal, where and what color is itis on my 1999 accent , I enven tried takiing picture s of the wires under the dash to see if it shows up, does any body know , its it just hanging or mounted?
[IMG]local://upfiles/6342/3D3BA6BDF5FF4B0BB899D6DB2175EB62.jpg[/IMG]
Old Jan 20, 2009 | 08:50 PM
jsinton's Avatar
Banned
Default RE: Cant find scanner connector under dash
It's not near the clutch pedal. It should be on the plastic molding on the left of the steering wheel. Just reach your hand under while sitting in the car, you should be able to feel it. It's like the easiest place to reach.
Old Jan 20, 2009 | 09:05 PM
2 days? Maybe it's time to go to a mechanic.
Old Jan 20, 2009 | 11:18 PM
Rhondas's Avatar
Is it just hanging from a bunch of wires ???or is it mounted securely in a bracket see the picture I took randomly with a hand held camera under the dash I have checked these areas wuith a hand held mirror and just cant seem to locate it.?
[IMG]local://upfiles/6342/91FF580C43F54CFAAA2932883CA4746A.jpg[/IMG]
[IMG]local://upfiles/6342/FF7D9B227C1E4046B57982F8DA02A47A.jpg[/IMG]
[IMG]local://upfiles/6342/72B036E04B5D4FA3ADF455172CF2F20F.jpg[/IMG]
Old Jan 21, 2009 | 12:19 AM
ken99's Avatar
Bingo!
[IMG]local://upfiles/4972/758EE8F21A36408EA78EB1A611CE6456.jpg[/IMG]
Old Jan 21, 2009 | 12:21 AM
Rhondas's Avatar
Is it just hanging from a bunch of wires ???or is it mounted securely in a bracket under the dash I have checked these areas with a hand held mirror and just cant seem to locate it.?
ORIGINAL: ken99
Bingo!
Old Jan 21, 2009 | 12:26 AM
ken99's Avatar
I had trouble getting the picture to copy over to my reply. You should see which one I was responding to now.
Old Jan 21, 2009 | 12:28 AM
Rhondas's Avatar
thanks for the picture, is it near the left of the sterring shaft or right towards the heater box
ORIGINAL: ken99
Bingo!
Old Jan 21, 2009 | 12:36 AM
ken99's Avatar
It your picture, don't you know where you took it? Perhaps this will help.
[IMG]local://upfiles/4972/E7A0DF083A244FE5B99C95EA9CFBCD68.gif[/IMG]
[IMG]local://upfiles/4972/990D0CC507D647C9955A34E3D220C601.gif[/IMG]
Look for item #20.
Old Jan 21, 2009 | 12:57 AM
Rhondas's Avatar
OK now Im seeing that # 20 is way upward to the far left nearer the fuse box is that where Im at am I getting close? because there is a mass of harness in there?
ORIGINAL: ken99
Look for item #20.
