coolant change help
hi, ive got a 2000 excel 1.5L and was wondering if there was another coolant drain plug on these engines besides the one on the bottom of the radiator?
thanks'love you |
RE: coolant change help
May I ask why you need to find a different drain plug?
On some engines theres a second drain plug, which makes it easier to flush the coolant and makes sure you get it all out. Just wondering if this car has one.
I thought perhaps you were having trouble with the existing drain.
The schematic for the same vintage Accent (U.S. version of the Excel) doesn't show a petcock anywhere on the block. I checked the engines on my Sonatas and a friends newer Elantra, and none had any. I would guess the short answer is not likely. |
