diagnostic codes pre-OBDII
How do I get diagnostic codes from my OBDI Hyundai? I know on Toyota or General motors, you can use a jumper wire and count the flashes on check engine light. Same with Hyundai? Which pins do I jump? I'm working on a 1992 Elantra which may have 1993 or 1994 engine. Thanks
RE: diagnostic codes pre-OBDII
To get the OBD-I codes for 1989-95 Hyundai'syou need ananalog voltmeter (a voltmeter that has a needle indicator, not a digital readout). Locate thediagnosticport(usuallyunder thedashon the left side of the steering column) andconnect the positive lead tothe "MPI" diagnostic pin on the top right corner of the port and connect thenegative lead to theground pin on the lower left corner of the diagnostic port.
Then turn the key to the ON/RUN position on and count thesweeps of the needle on thevoltmeter. For example: A code 13 is shown as 1 sweep of long duration followed by 3 sweeps of short duration. Also if there are more codes, it will be shown in numerical order. Here are some popular obd1 codes for Hyundai 1989-1995 vehicles: Code 11 Oxygen sensor Code 12 Air flow sensor Code 13 Air temperature sensor Code 14 Throttle positioner sensor Code 15 Motor position sensor Code 21 Engine coolant sensor Code 22 Crank angle sensor Code 23 No.1 cylinder top dead center sensor Code 24 Vehicle speed sensor Code 25 Barometric pressure sensor Code 41 Injector Code 42 Fuel pump Code 43 EGR Code 44 Ignition coil fault Code 59 Oxygen sensor fault |
