diagnostic codes pre-OBDII
Old May 28, 2008 | 11:16 AM
tiopancho's Avatar
Default diagnostic codes pre-OBDII
How do I get diagnostic codes from my OBDI Hyundai? I know on Toyota or General motors, you can use a jumper wire and count the flashes on check engine light. Same with Hyundai? Which pins do I jump? I'm working on a 1992 Elantra which may have 1993 or 1994 engine. Thanks
Old May 28, 2008 | 11:47 AM
Default RE: diagnostic codes pre-OBDII
To get the OBD-I codes for 1989-95 Hyundai'syou need ananalog voltmeter (a voltmeter that has a needle indicator, not a digital readout). Locate thediagnosticport(usuallyunder thedashon the left side of the steering column) andconnect the positive lead tothe "MPI" diagnostic pin on the top right corner of the port and connect thenegative lead to theground pin on the lower left corner of the diagnostic port.
Then turn the key to the ON/RUN position on and count thesweeps of the needle on thevoltmeter. For example: A code 13 is shown as 1 sweep of long duration followed by 3 sweeps of short duration. Also if there are more codes, it will be shown in numerical order.
Here are some popular obd1 codes for Hyundai 1989-1995 vehicles:
Code 11 Oxygen sensor
Code 12 Air flow sensor
Code 13 Air temperature sensor
Code 14 Throttle positioner sensor
Code 15 Motor position sensor
Code 21 Engine coolant sensor
Code 22 Crank angle sensor
Code 23 No.1 cylinder top dead center sensor
Code 24 Vehicle speed sensor
Code 25 Barometric pressure sensor
Code 41 Injector
Code 42 Fuel pump
Code 43 EGR
Code 44 Ignition coil fault
Code 59 Oxygen sensor fault
Swampy
Mar 17, 2010 08:20 PM
Bubs
Dec 6, 2008 11:54 AM
JaloperMatt
Aug 21, 2008 09:59 AM
proudsalesman
Mar 20, 2006 01:38 PM
bengy678
Feb 16, 2006 12:27 AM
