Electrical Problems
Hi, i have this problem with my gas gauge, everytime i full my tank my gauge reads empty . It stays that way untill about half, when it would probably start reading again when ever this happens it is irregular could anybody advise me what could be causing this?
RE: Electrical Problems
What year and how many miles. I'd say it's the sending unit in the tank. If you have an ohm meter, you can check the resistance as the rheostat in the tank is moved up and down.You should get avariable reading and gradual change. If you have a lot of miles on the car, like over 100k, would not hurt to change the pump/sending unit while you're in there. Not knowing the model and year, it may be that the pump and sending unit areone unitand will have to replace as a unit.
Chances are the fuel tank is accessible by removing the rear seat, then the cover underneath it. You should see the top of the gas tank with the connectors for the sending unit (fuel pump & gage). Disconnect it and remove the fastener that holds in the unit (usually a big locking ring) and just pull the pump up. If you buy a new pump, it will probably be in the neighborhood of $200 (not including installation).
I have a firing problem with a91 excell. spark is sporatic and it started with a miss and got worse untill now it trys to crank but its like wires are not in order but they are.have a ignition problem where sometimes switch slips back and turns car off dont know if this related or not. can anybody shed some light on this.
