Engine noise- oil?
I have a 97 lantra 1.6 gls and has 180k miles on it . The engine started to make a nasty clicking noise recently its loud, and there continously. Ive heard changing the oil helps but this is my first car and I dont have a clue so any help will be great ie: what is the best oil to use.
At this point you probably want to buy one of the oils specially formulated for high-mileage cars. Make sure it meets all oil requirements (viscosity, etc.) for your car. Is it the engine itself, or might it possibly be the exhaust manifold? Sometimes an exhaust leak can sound like a ticking noise. If that's the problem, it's a relativelystraightforward fix. If it's the engine itself, your engine is probably getting ready to die (although it might last quite a bit longer before it goes).
