ESC, ABS, *and* AWD lights on
Hi there,
So I was in to my mechanic's on Friday to get an oil change and switch to summer tires (on separate rims) on my 2011 Hyundai Santa Fe. No issues on the way home. Yesterday, I drive for a bit, park for about 15-20 minutes. I start it, start driving and notice that the ESC warning light is on, the ABS warning light is on, and the AWD system warning light is flashing
Seems this is not an entirely uncommon problem but I haven't many reports back of what fixed it.
One thing to note: of the tires put back on on Friday, 3 are quite worn and 1 is virtually new (had an accident last fall, got a replacement wheel/tire in the process). Will be in contact with my mechanic tomorrow but has anyone had the same experience? Is it possible that the different tread depths on the tires could throw things off that much? Just hoping that the resolution is not too expensive, this thing is now starting to cost money on a regular basis....
Thanks in advance,
Steve
Seems this is not an entirely uncommon problem but I haven't many reports back of what fixed it.One thing to note: of the tires put back on on Friday, 3 are quite worn and 1 is virtually new (had an accident last fall, got a replacement wheel/tire in the process). Will be in contact with my mechanic tomorrow but has anyone had the same experience? Is it possible that the different tread depths on the tires could throw things off that much? Just hoping that the resolution is not too expensive, this thing is now starting to cost money on a regular basis....
Thanks in advance,
Steve
Hi Wolfpark,
Have you found what was the issue? I am having the same issue. The ESC light came on several times (and sometimes the check engine and AWD light along with it) in the past for me but whenever I restarted the car it went off. This time ESC light came on and now the check engine light but ESC light is gone and not the check engine light.
Hi there. Yes, the issue turned out to be that the ABS sensor on one wheel had stopped functioning. Once that was replaced, all was well again. Your issue may be a bit different as all three (ESC, ABS, and AWD) always came on together for me. Best of luck in resolving your issue!
My local mechanic fixed it; don't recall how much it was unfortunately.
