headlight problem
I have a 2005 Santa Fe and the dim lights quit working. I have checked the fuses that are associated with the headlights and they all seem to be ok. The fog lights work and the highbeams work. I have turned the light switch to all settings and they just won't work. I have not removed a bulb yet because I can't hardly believe they would both go out at the same time. Any suggestions?
thanks |
Well, I did not get any suggestions so I went ahead and replaced both bulbs and they now work. I find it odd that both bulbs blew out at the same time but I guess stranger things have happened. Hope this may help someone else sometime.
Foound your post while looking for help on my issue....our 2006 SOnata eats headlight bulbs every 15k miles or so....but one at a time....
Hard to buy light bulbs that last... ever buy a bulb at store, only to get home and install it, flip the light swith and the bulb flash at you... hate it when that happens.
