Key Fobs not working outside of car
Hope I'm posting this in the right place! I searched for another thread to help, but didn't find one quite like this.
2012 Hyundai Elantra Limited. Currently 71k miles. Everything was working just fine until our recent cold snap a few days ago. Went outside and pressed my unlock button on the door handle. Nothing. Hit unlock and lock on my key fob. Nothing. I figured the battery was dead (temps around 10 degrees), but the car started up just fine when I was in it. I tried to lock the car with the keys in it and it wouldn't lock, so it's recognizing the key if it's inside the car. Did some quick tests with both smartkeys (main and backup) after changing the batteries in the keys: 1. If the car door is closed and the fob is outside of the car, the fob will NOT work. 2. If the car door is open and the fob is outside of the car it WILL work. 3. If I'm inside of the car with the door open, it will work. 4. If I'm inside the car with the door closed, it will work. It just seems like the car won't recognize the fob if it's outside of the car and the door is closed. I'm going to try disconnecting/reconnecting my battery tonight to see if a reset will help. I was planning on trading the car in this week so I'm desperate for help =/ All advice is appreciated!! |
Hi. This is crazy. Because I am experiencing the same thing. When it gets cold outside. It seems like the car doesn't respond to the fob. Or it will respond intermittently. But, when the weather warms up. It works perfectly. I changed the battery in the remotes. But, the problem is still there. Not sure where to check now.
Originally Posted by mdobb
(Post 53917)
Have the same problem but with Elantra 2015 Supreme
Originally Posted by Crusher560
(Post 62463)
some time I go and come back and it’s works, some time I lock the car and it works, but sometimes I wait more then a hour. tried to replace battery but don’t work. can some one help us? |
Can you tell us if the problem is confined to only the driver's door or all the doors?
The problem is way bigger
Originally Posted by hanky
(Post 62467)
to open the door it’s not a big problem because there is a way to open the door with physical key that is in the remote. the real problem is that some times the car doesn’t start( the problem isn’t in the starter), There is a light that show that key not detected |
The interior of the key switch assy may have a loose connection or be worn requiring replacement.
| All times are GMT -5. The time now is 03:23 AM. |
